instrument cluster lights problem
snoops
Major Helmet
Post Sun Mar 04, 2007 12:31 pm
i removed my instrument cluster to paint the dials red, put it back but the trim around it doesnt fit as snug as it was before, also the rev counter stopped working then came back on and the light for the speedo stopped, everything else stayed on, i gave it a few knocks and comes back on?
im thinking probably a loose connection but can anyone tell me which connection it could be?
Post Sun Mar 04, 2007 3:19 pm
There are two connectors on the back of the cluster, blue and white. If the locking bars are fully in there should be no poor connections here. Also everything in a BMW goes back as if it has never been disturbed, so the short answer is work out what you've done wrong!
If the plugs are fully in, you've possibly cracked the solder joints where the pins join the PCB.
