rear abs sensors
timmyboy
Post Sat Mar 03, 2007 6:47 pm
hi, not sure if im bein blind or stupid or perhaps both,
i cant seem to find the rear abs sensors, its an1989 f reg 325i se, there should be rear abs??
cheers
(00=[ll]=00)
Image<embed></embed>
old_skool
Post Sat Mar 03, 2007 6:49 pm
They are in the trailing arms, front side, by the wheel hubs.
timmyboy
Post Sat Mar 03, 2007 7:05 pm
same kinda location as the ones in the front then, really doesnt appear to have any,
(00=[ll]=00)
ric325i
Post Sat Mar 03, 2007 7:13 pm
seems strange to have them in the back!?!
in theory under braking the back shouldnt need ABS unless its a sideways slide i guess? but i thought e30's went sideways under power :D
i melted my front ABS sensor cause it got jammed under the pad some how :cry:
made me laugh though.
old_skool
Post Sat Mar 03, 2007 7:22 pm
ric325i wrote:seems strange to have them in the back!?!
Are you sure that wasn't the brake pad wear sensor? Where the ABS sensor sits in the front struts would be nigh impossble to end up in the caliper, especially as it is recessed into the housing and bolted in with an M4 allen bolt.
The E30 ABS unit has individual supplies to the the near side front caliper, off side front caliper, and a combined supply via a brake bias valve to the rears. Although the ABS function to the rear is controled by individual wheel sensors. The easiest way to find them (or check you have them) would be to follow the sensor cabling down the trailing arm and up into the sensor itself.
timmyboy
Post Sat Mar 03, 2007 8:42 pm
found it
(00=[ll]=00)
