help with rear seat replacement
boxclever1753
Post Thu Mar 01, 2007 12:15 pm
is it an easy job to take out the old rear seats in my 2 door and replace them with leathers? i have a couple of hours this afternoon and thought i may give it a go.
if not then it can wait until i have more time to lavish on her.
thanks.
Theo
Post Thu Mar 01, 2007 12:23 pm
Very simple indeed. To get the base off, just pull it up, it will come straight off. For the seat back there is one 10mm hex headed screw on each side going through a metal tab on the seat, into the body. Take these out then push the seat upwards firmly and it will come straight out.
oze30
Post Thu Mar 01, 2007 12:24 pm
To remove the seat base, just feel under the base for 2 indents.. one each side. and lift. They're just held with pop on thingys.. you'll see when you take it off.
The seat back, you'll have to look at the base of the seat where the seat belts bolt in, and you should see an 8 or 10mm bolt either side. Undo these and the seat will be free from the bottom. When you lift it up (The whole seat towards the roof) it will come off a bracket on the bulkhead and then you'll just have to finagle it to get it out.
Now's a good time to check your rear inner arches (you'll need to remove the rear cards, but for the hassle of 5 mins each side to check if your arches are going holey!
Good luck!
boxclever1753
Post Thu Mar 01, 2007 1:24 pm
wow - thanks guys!!
i'm out to do it now - will report back!!
i need to be done in a hour or so otherwise some passengers will have to sit on the floor!!
boxclever1753
Post Thu Mar 01, 2007 2:10 pm
thanks guys - job done! 10 minutes for this fat bloke!
the old seat base was slightly damp underneath buut i don't have the time to look at this today. it is clearly something i need to revisit when i next work on the car.
thanks again - a really easy job even i could do!!
