HELP!!
tristan325
Post Thu Mar 01, 2007 11:09 am
OK I tried searching, but couldn't seem to find anything relevant.
Been pissing down the last couple of days and as a result my rear bench on the offside is soaking. It would appear that it got wet from the underneath and the damp patch is localised in the area where the bench meets the seat back. I pulled the bench out and the area underneath is also wet.
A quick check failed to reveal any obvious areas of water ingress? Anyone experienced this before or have any suggestions? I'm thinking it might be the rear window seal? Although it does appear to be getting in from underneath.
Any help is greatly appreciated
dazleeds
old skool raver
old skool raver
Post Thu Mar 01, 2007 11:16 am
from experience i would say the sunroof rear drain tube has corroded
this means the water runs down the outside of the rubber tube down thru the rear pillar and then goes under the back seat
which after a good day/nite of rain will soak the seat going thru the foam
and ending up wet on top as well
remove the grab handle on roof and door seal pull back the rooflining just a little and you can see
where the rubber tube joins metal in the roof
this is probably badly corroded
hope that helps
Daz
www.oldskoolfantasy.co.uk
tristan325
Post Thu Mar 01, 2007 11:23 am
Cheers Daz.
Your a legend I didn't even think of that! I owe you a pint next I'm in Leeds.
dazleeds
old skool raver
old skool raver
Post Thu Mar 01, 2007 11:37 am
whatever you do dnt pull on the ruber pipe
i did this and it broke away from the rest instantly :cry:
id say to fix youll need to remove back end of the rooflining clean it all up and have a new metal piece/tube welded on to fit the rubber hose too
or possibly just seal it with silicone but that depends on whether this is gonna be your car long term
it may not be this but it does sound exactly the same as mine went
tristan325
Post Thu Mar 01, 2007 11:52 am
So is the rubber tube likely to have perished and need replacing?? Or is just the connection? Also which end should I start removing the headlining from? I.E. Where is exactly is the problem area I should be looking at? The wet patch is on the drivers side if this makes a difference.
P.S. Where abouts in Leeds are you? I'm ex Chapel Allerton.
Post Thu Mar 01, 2007 12:04 pm
have you got opening rear windows?
often the seal on those are shagged out of their brains too
tristan325
Post Thu Mar 01, 2007 12:06 pm
E30BeemerLad wrote:have you got opening rear windows?
Yup! Plan on changing those also, as soon as I find a source.
dazleeds
old skool raver
old skool raver
Post Thu Mar 01, 2007 12:10 pm
rubber tube is probably fine
its the metal tube that corrodes or did on one of mine anyway
the area you want to look at is about 6to8 inches from the rear screen
so wherever is easiest in relation to that is where you wanna unpeel the lining
you only need it loosened to check dosent have to come right out
316eyes
Post Thu Mar 01, 2007 12:55 pm
Drain tubes can also block.
Try a long piece of stiff wire poked doen the outlet you can see with the sunroof open. Gently for the first part in case it is badly rusted as Daz says.
Had exactly the same problem but now OK.
I'm not completely perfect.......there are some bits missing or broken.
But the weather here helps!!!
dazleeds
old skool raver
old skool raver
Post Thu Mar 01, 2007 1:02 pm
316eyes wrote:Drain tubes can also block.
coax tv aerial wire fits perfect :D
tristan325
Post Thu Mar 01, 2007 1:20 pm
Thanks for all your help guys! Hopefully it doesn't rain at the weekend! Boy am I gonna be busy what this and central locking issues and valve clearances!! :D
316eyes
Post Thu Mar 01, 2007 1:35 pm
Welcome to E30 world. :D
