starting problem
slippo
my 325 has a slight problem on start up, it fires up then if you dont give it some throttle when she fires it cuts out, usually when warm starts ok? is this the cold start valve? any ideas what can be done?
316eyes
Better posted in the Tech Help section, mate.
I'm not completely perfect.......there are some bits missing or broken.
But the weather here helps!!!
delboye30
