Throttle plate set up ?
exup
Boost Junkie
Post Sun Feb 25, 2007 12:14 pm
Hi ,
I ve removed and cleaned up throttle body and switch ,
I want to set up throttle plate to housing body , manual says set .015 " clearance inside from throttle plate to housing body , is this right as it seems too big ?
As screw adjustors approx 7 mm out ???
I would have thought setting would have been fractional cleance beteen throttle plate to housing body ie .003" so adjustor stop is taking all pressure of spring and stopping pressure on throttle plate , then set up switch to that setting ??Assume so clerance is need to allow it to idle and stop IVC from hunting to much, ie damp it a bit , but .015 is appears too big ??
smithy318i
Post Sun Feb 25, 2007 1:33 pm
exup
Boost Junkie
Post Sun Feb 25, 2007 3:27 pm
so it a[ppears .015 2 itis , but thats massive amount the butter flys open,
compared to all the ones i ve taken off in the past :?:
Post Sun Feb 25, 2007 3:33 pm
READ IT AGAIN! Says 0.0015"!!
smithy318i
Post Sun Feb 25, 2007 3:42 pm
It should be 0.04mm or 0.0015 inches
