Where is the central locking control unit situated?
speedfreak
Post Sat Feb 24, 2007 1:54 am
Hi all .
I need to find out where the central locking control unit is situated on a 1992 325i cabrio e30 ???
I'm hooking up a remote central locking system and i need to nick some wires from that unit.
Can anyone help?
mac325i
Post Sat Feb 24, 2007 4:33 am
The central locking relay/ecu is located in drivers foot well (assuming its RHD).
Remove kick panel speaker cover, there should be 2 screws below the speaker, these hold the relay to a bracket. remove speaker and the 2 screws and pull the relay out through the speaker hole.
Hope this helps
carlos_320i
Post Sat Feb 24, 2007 10:25 am
If it is not there in some cases it has been moved to just above the ECU as in the speaker well it can get wet
Post Sat Feb 24, 2007 10:30 am
You don't need to go anywhere near the locking ECU to connect an alarm!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Stop vandalising your wiring looms and do the job properly.
Most, if not all of the wires you need are in and around the glovebox area.
Archie14f
Post Sat Feb 24, 2007 8:22 pm
Do As Brian Says He told me were to wire mine up everything was exactly were he said and it works perfect
check out thread from a couple of weeks ago Fitting Scorpion Alarm
