Coolant tank erupts h-gskt. now dead...
goosiegander
Zonegoose
Post Fri Feb 23, 2007 1:00 am
Mortified to say that my m20 320i head gasket failed spectacularly earlier... temp gauge red, pulled over, let pressure off coolant tank slowly, entire emulsified contents of coolant system explodes out, tried refilling t/k with water but it appeared to run straight into the engine... is this a gasket failure or a cracked cylinder head? any thoughts please...
Best regards, Goosie
Post Fri Feb 23, 2007 9:09 am
Catastrophic failure like this is probably head gasket, but it isn't going any further without major attention, so take the head off and see. Head can also have cracked as a result, of course.
goosiegander
Zonegoose
Post Fri Feb 23, 2007 1:33 pm
much appreciated thanks for the reply
