Brake light wont go off
sam325is
Wed Feb 21, 2007 7:24 pm
my brake lights on the clusters wont go off.
when the brake pedal is pushed they just blink and stay on.
any ideas?
dobbie82
Location: Dolgellau, Wales (NOT A TRADER,broken a car,got lots of bits)
Wed Feb 21, 2007 7:30 pm
there is a little switch behind the brake pedal easy to take out, perhaps its sticking on?
e30 related ebay auctions + shop(MY Stuff for Sale), http://tinyurl.com/64aufr
My Feedback on the e30zone: http://tinyurl.com/dobbie82feedback
Cotty
Hartge Crew
Wed Feb 21, 2007 7:38 pm
dobbie82 wrote:there is a little switch behind the brake pedal easy to take out, perhaps its sticking on?
Thats what I thought, I had the same problem. Changed mine recently £9 for the switch from the dealers
Wed Feb 21, 2007 9:04 pm
It won't switch off if the brake pedal isn't coming up far enough to work it. In this case the pull rod that goes across the car behind the heater box will need adjusting slightly.
tylerma
Wed Feb 21, 2007 9:09 pm
sam325is wrote:my brake lights on the clusters wont go off.
any ideas?
when you say clusters do you mean the instrument cluster
on the dashboard
if so it might be your brake sensor
you have 2 nearside front and offside rear
so your pads could be due a change
sam325is
Wed Feb 21, 2007 11:55 pm
no i mean the rear lights. it just suddenly started happening. i will have to investigate tommorow, thanks
m3mpower
Wed Feb 21, 2007 11:59 pm
i'm sure its something to do with the brake light switch which is located behind the brake pedal.
ajay31
Thu Feb 22, 2007 8:10 am
the brake switch usually sticks, remove from top of pedal and push it into housing gently it will click when back at right position.
sam325is
Thu Feb 22, 2007 11:38 am
i just went outside and pulled the connection plug out and blew on it, then pushed the switch(didnt hear a clcik though) and now its all fine.
thanks for the help guys/girls
