Changing ABS pump
wildeian
Post Wed Feb 21, 2007 7:12 pm
Once this is done, is bleeding the brakes all I have to do, or is there more?
Cheers, Ian
Post Wed Feb 21, 2007 9:02 pm
Bleeding should be all you have to do, but try to keep the new unit as full of fluid as you can. It will bleed through OK, but if air gets into the deeper recesses of it, it can be difficult to get out without the use of a special BMW tool that electrically operates the valves and pump.
wildeian
Post Wed Feb 21, 2007 9:42 pm
Once again, I thank you Brian! :notworthy:
