P/S rack 318i & 320i
320iAN
finaly went out and got me a replacement power steering rack today from a 318i, will it fit straight on to my 320i or do i have to change the hose's/pipe's
(it's dark out side now and i can't see the pipe's clearly)
P_VIDDY
should fit no problem
320iAN
hope so ..
it's the only one i found in all the breakers yard's i tried! the fitting all look's the same, but i'll know better when ive got mine stripped of and the 2 sat side by side .. might be easier/quicker if i just unbolt the fluid pipes from the rack instead of disconecting the pipe's at the pump and resivour bottle?
BONUS find today was: 2 spankin brand new rear gas shock's, origonal boot box/tidy and the rear black number plate panel, i was so glad that the E30 i found had a full system of fluid in it's P/S rack ...
dunno if i'd have taken it if it was dry?
all the above for £60
Check under the rubber boots on your new rack. There should be no steering fluid in there at all.
All E30 RH drive power racks are the same, but for some reason they were different on 4 and 6 pots used different manual racks.
320iAN
Brianmoooore wrote:Check under the rubber boots on your new rack. There should be no steering fluid in there at all.
forgot to add i also got clear side repeators and i took the coil (spare) from the scrapped E30
Chris-W
320iAN
Chris-W wrote:Suggest you disconnect the hoses at the rack if you're putting a 6-cyl rack on a 4-cyl.
