2 Door water - leak
Knobead
Post Sun Feb 18, 2007 7:23 pm
Evening all, got a 2 - door e30, only just started noticing a water leak
today in the boot space were the jack goes and were the battery goes
om bigger engined models,
Any ideas were its coming from any help appreciated?
sam325is
Post Sun Feb 18, 2007 7:39 pm
is the water that is getting in on both the jack side and battery side?
Knobead
Post Sun Feb 18, 2007 7:41 pm
Yeh it is mate more the battery side though , almost deep enough for a goldfish to swim in any ideas??
sam325is
Post Sun Feb 18, 2007 7:58 pm
yes. that is rusted out rear arches, im almost 100% sure of it. the fact that you say that there is more water on the battery side makes me think this. the battery side (petrol cap side) usually rusts out more due to all the brackets for the vapour bottle.
Knobead
Post Sun Feb 18, 2007 8:03 pm
That don't sound good i was hoping it would be a boot seal or something, cheers sam i'll check it out tomorrow
see whats going on.
TheDutch
Post Sun Feb 18, 2007 8:46 pm
Check rear light seals, sunroof drains, aerial fixing, shock top mounts, rear window 'hockey stick' trims, could easily not be rust.
rj
Post Sun Feb 18, 2007 9:10 pm
In most cases it is the boot seal, the rear lights seals, the sunroof drainage hoses and the radio aerial grommet which creates these leaks. Additionally, it can be the window and finisher panel seals also.
Get someone to sit inside the boot with a torch with the lid closed and spray water from a garden hose over those suspect areas. That should give you an insight as to where the water is coming in if it is a seal or sunroof problem.
Good luck!
Knobead
Post Sun Feb 18, 2007 9:13 pm
Thanks fellas for the suggestion i'll have a crack at it tomorrow, just gotta persuade someone to get in the boot
at work might be a problem, i've got to sort it before it starts to rot out thanks again all, knobead.
Post Sun Feb 18, 2007 10:02 pm
I'll go with Sam325iS, I'm afraid, as it's what my experience suggests.
However, all the other suggestions are all valid, so you may be lucky.
