What do people think of the foam gun attachments ? Are they compatible with ZAINO products ?
Regards
Rob
Foam Gun
ive used one with z7 in it
personally if iam using zaino products i wouldnt mix and match with other soaps
it foamed ok but not aswell as if u use some of the products designed to be used in these guns
its a good form of presoak for dirty cars to remove bulk of shyte
still going to have to wash it tho
jon
jon
Foam guns are good, as Jon says specifically if the car is properly dirty. The foam clings and soaks some of the dirt off, give it a rinse, then wash it properly using the two bucket/grit guards/wash mits and you'll do a good job of not scrubbing dirt into the paint.
