Just a couple of questions...
Which models had an LSD as standard, and which had an LSD as a specifyable option? And in what years?
Also, what ratios do the standard LSD's come in?
Thanks chaps!
E36 LSD's
stuartgallafant
Motorhole
Thanks Stu! 3.15
long ratio...
What LSD's/ratios from other BMW's may fit the E36? Thanks!
Andyboy
- Alpina Colada
M3 Evo diff is a Typ 210 (7 Series size) which requires the whole rear axle. Other 6 cyl E36's use a Typ 188 which is the E30 325i-M3 diff in a different casing. Find an E30 or 525i/535i Sport (Post 1991) LSD and get a specialist to swap the LSD pack into the E36 diff.
Motorhole
Excellent, thanks chaps!
