Hi Lads,
I'm going see a cab in the next few days but it's quite a distance away and I just wanted to vet the car with the guy who's selling it over the phone before I travel over to see it.
Are there any particular things that are relevant to cabs that I should be finding out to save me wasting my time?
Any help or suggestion is appreciated no matter how simple or obvious it may sound.
Thanks in advance.
Stevo
Cab Questions
mrLEE30
the main enemy of E30's is rust, so with all cars you will want to avoid a rusty one. fortunately cabs seem to lead an easier life then tin tops, normally being a summer or second car, and they are noramlly garaged more then a tin top.
as for questions..what engine.model is it 318,320 or 325, what year? is it the face lift or not (they changed around 1990/91 IIRC for the cab)
then the most important is the roof, does it have any holes, is it electric or manual. a badly torn roof will set you back around 500-700 quid to replace and if the car has an electric roof the motors and control arms are also extreamly expensive as they are only a dealer item (scrap electric cabs are rare as rocking horse teeth)
then when you get there check the usual spots for rust, if it has a body kit on, especially a tech 2 remove the door panels and check for the tin worm underneath, remove the carpet in the boot and check for rust around the rear light clusters.
also check the electrics, especially rear windows.
then get in the car and drive with roof up, how is the wind noise? if possible have the seller spray a hosepipe on the roof while you sit inside to check for major leaks (some small amounts of water getting in around the top of side windows is not a major problem) and finally check the roof folds down smoothly (do it five or six times if its electric) and dont be tempted to do the test drive with the roof down, always test a car with the roof up and the stereo off..that way any strange noises can be heard...if you buy the car there will be plenty of time for topless tunes on cruising.
good luck
mrlee
good luck
mrlee
DaveD
- E30Zone Wiki Specialist
stevo_sideways
Thanks lads
I've owned a few E30's but I didn't know whether there was anything specific on Cabs that I should be looking out for as I've never had one.
Cheers.
Cheers.
orangecurry
Make sure the rear-view mirror is fixed on the glass securely - not serious if it isn't, but it's a bargaining point.
Stick your fingers in the rear-wheel arches - make sure the gap between tyre and arch is the same on both sides of the car.
Look along the side of the car from the rear - make sure there are no ripples in the paint/metal directly ABOVE the rear wheel arch - if the cab has had a rear accident, they can twist slightly, and it shows above the rear arch.
