Is it possible to remove them for proper cleaning or perhaps refinishing without completely taking the headlight assembly out? On the later cars they're a grey painted affair, the earlier ones were chrome. The grey ones discolour and are impossible to clean
I can take the headlights out; just don't want to do more than I have to…
Many thanks
Andrew
Headlamp "Ornamental Rings"
Geeman
Yes... they just clip off... so you can even paint them matt black.
Just unbolt the headlight carriers (so they both come out with the bracketry) and you can get to the trims a lot easier.
Hope this helps...
Giles.
Hope this helps...
Giles.
AndrewL
Thanks.
Can you unclip them without unbolting the carriers? With or without removing the grill?
Andrew
Andrew
Geeman
Not tried.
Try taking off the two front grilles... might give you a bit more room to 'spring' them off with a screw-driver...
d6dph
Easily come off with the grille removed
toughguych
They are plastic coated so if you are thinking of striping them...
Be prepaired with plenty of paint striper and wire wool!
sam325is
i just sanded mine with extremely fine sand paper and sprayed over them in plain silver
