Throttle body upgrade
raulandthetwins
Post Wed Feb 14, 2007 2:15 pm
Yes once again i'm begging for your help!
The guide made it look easy enough so i thought why not, sourced the 2.5 throttle body of ebay(alpinajon top bloke) but do not have the boot/bellows i have been to my local dealer and so far been supplied two that are wrong!!!!!
I need the part number for the one to fit mine
The idle control valve is T shaped
There is a pipe coming off after the bent
In fact it's the same as the one on the tech menu picture, who's car is that? are they sure they really need it?
Hope someone can help
Many thanks raul
Ohh the part number is underneath just to make life easy!!!! :mad:
DaveD
E30Zone Wiki Specialist
Post Wed Feb 14, 2007 2:25 pm
raulandthetwins
Post Wed Feb 14, 2007 2:58 pm
Yes it does mate i have been looking through putting in different years there appears to be that they used so i give the part number i've not had a shot!!!!
Cheers for your help
Also i'm i being think i couldn't see this website in the links section? :D
DaveD
Post Wed Feb 14, 2007 3:21 pm
It is on as a sticky in the technical section...not in the links ...put you vin no in and it will come up with what fits your car...that one was for mine a 92 cab
