help timing chain markings t reg bmw single valance engine
adaptorman
hi all i bought my first bmw grrr its been runing fine for around 4months then i noticed starting loseing water and overheating ,and bad starting so i removed the head and had it skimed and replaced the head but as its done 113000 i thought id replace the timing chain ,problem is after my clyinderhead was overhaued the timing marks need alineing up ,can anyone tell me how there are alined up or a daigram so i can get my motor runing/seen some arrows but unsure were they go and unsure about crank mark settings
fuzzy
a t reg? whats that ,an e46? best to ask the correct forum. theyre most likely to know
try www.e46fanatics.com or www.e36coupe.com if its that model.
adaptorman
thanks evern thow its a treg its the earlyer looking front end model ,maybe on the change over the engines like this if anyone has any idea
There are no timing marks. You need a tool that slots over the rear of the 2 camshafts to hold them in timing position while you tension the chain.
This is precision engineering you know, its not like timing up that thing in fuzzys sig
