door alignment
domross
Mon Feb 12, 2007 5:12 pm
The drivers side door on my cab is misaligned...it sits slightly higher when closed and the bottom of the door toes in ie the window/quarter light sit slightly out from the seal at the top corner it also doesn't close cleanly on the striker....is there a specific adjustment to make or is it a case of loosening off the bolts on the hinges and shifting the door around til I'm happy? (the gaps between the panels look reasonably straight)...Cheers
domross
Tue Feb 13, 2007 6:54 pm
anyone??
Templ8e30
Tue Feb 13, 2007 6:56 pm
If the gaps look even then you'll need to add or remove shims from between the hinge and the door, loosen the bolts on 1 hinge and slide out the shims or add as necessary to get the alignment spot-on.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
domross
Tue Feb 13, 2007 7:07 pm
Thanks Iain
DaveD
E30Zone Wiki Specialist
Tue Feb 13, 2007 7:10 pm
I have just re-aligned mine and be warned...they are HEAVY...i used a small trolley jack to support the door whilst messing with the hinges............
