325i touring tailgate problems!
jagtech2002
Post Mon Feb 12, 2007 3:55 pm
hi guy's just recently treated myself to a 325i touring but cant get =the tailgate open, does any one know how to open them from inside the car? pls help!!!
oze30
Post Tue Feb 13, 2007 12:47 am
Do a search..
but from memory, you need to remove the black plastic trim on the boot lid/boot trim (the carpet thing with the half turn studs)
8mm wrench, undo the 2 nuts that hold the U latch to the tailgate. Then it should open.
When you get it open, you can undo the central locking solenoid by the 2 x 6mm (I think) screws that you can see, then you should be able to get in/out without hassle.
