m535i dogleg in a 335i cab!! will it fit??
TheConverter
Hi guys, i have both an m10 manual box and prop, and i also have a dogleg box from an m535i e28, does anyone know if this will fit ok and if i can still use the e30 m3 prop, many thanks again guys
bigdek
gearbox will fit .
not sure on the prop but probably ok
Toby_Unna
- Boost Junkie
will certainly fit, using an e30 crossmember from memory.
make sure it's a good box though. they aren't that strong and a lot have noisy bearings which aren't cheap to sort.
i'd use a getrag 260 from an e34/e32 530-535-730-735 without question, a far better box
Gunni
yea the dogleg is weaker but not like it´s crap,
it´s also very cool to have a dogleg
I have one extra lying in my garage
TheConverter
will the dogleg give better speed times, cos i also have a 260 box layin around, dont really care about the dogleg, just want the better times!! I'm ruuning about 250-60hp with a 3.46 diff......
Toby_Unna
- Boost Junkie
3.46 will be much too low geared for the dogleg box, i.e. about 120mph actual speed on the limiter in top (prob 110 on the speedometer).
i would use the 260, having owned several screwed doglegs.
TheConverter
thanks for the advice mate, i will go for the 260 box then, do i have to use an e30 m3 prop, will anything else work you know of. i have like a million old bm props at my garage!!
bigdek
e36 328 manual prop with an e30 centre bearing fitted backwards seems to be getting more popular.
cheaper and more readily available than e30 m3
Toby_Unna
- Boost Junkie
er, what i meant was it will do 110 max but read 120 lolToby_Unna wrote:3.46 will be much too low geared for the dogleg box, i.e. about 120mph actual speed on the limiter in top (prob 110 on the speedometer).
low gears isn't good with this conversion, you just end up with a useless 1st gear and effectively a four speed box!
