Chaps,
I need to remove the crank pulley from my M42, however the engine is sat on an engine stand so i can't lock it up by putting it in gear!
Whats tricks have you guys got for doing this?
Removing Crank Pulley
Kedge
Ive found the best solution with engine on a stand is to heat the bolt (until the oil seal melts hot) then an impact gun will bring it out easy.
This was with M50/52 engines but I dont think the torque setting is too different
Kedge
Sounds like a plan, although i haven't got an impact gun so a big bar may have to do!
Turbo-Brown
- Boost Junkie
I put a 10mm dia stick of ali in between the middle two cylinder's counterweights and the inside of the block to stop the crank turning on my M20.
A big bar and the mass of my fat dad was then used to get the bolt out
Hammer handle jammed between a crank web and the block is the usual way if the sump is off.
E30Mark
I had to give up trying to undo the crank nut on a M42 when it was on the engine stand. Had the sump off and jammed the crank, but no matter what abuse i gave it the thing would not move. I was trying to be good and change the timing chain gasket whilst the engine was out, but ended up putting the engine in the car without changing the gasket. Thankfully the old gasket was fine and never leaked.
PM for details
PM for details
Kedge
Got it off in the end, jammed the crank with 3/4" drive extension which i put in an old water pipe. Then after heating it up with a blow torch for a few mins she was ready to go with a fair bit of weight! Not too difficult in the end
