After searching for a few months now i finally bought myself a E30 its a 316i Lux on a H plate in gloss black with 117k on the clock. Checked for the usual rust issues and it appears solid. The car has some service history but not full. There are a few things that need to be looked at firstly the temp guage doesn't work (fuse or maybe sensor) and also on take off the diff tends to make like a whining sound but then goes away at higher speed is this normal? if not what needs to be done?. Does anyone know if these come with abs as i have had cars in the past and hate the system.
thanks
Finally got my self an E30
Chris-W
Temp gauge is possibly a failed brown temp sender (located under the inlet manifold).
Best course of action for the whining diff is to monitor the sounds and get ready to replace it if it becomes noisy.
If you want to check if you have ABS, without slamming the brakes on, have a look behind the passenger headlight in the engine compartment - if there's an ABS pump (gold-coloured metal block with a black plastic cover with ABS on the top), then you have!
snoops
- Major Helmet
ive got a whiney diff on my 325 mainly in first gear then it gets quiter
