MOT pass!!!
RugbySteve
Post Fri Feb 09, 2007 12:03 pm
Just had garage on phone and apart from four new tyres (just fitted!) my little 1986 318i has sailed through the mot!!! Best bit is no work was needed on her before she went in and is a true testament to how these cars were made and that if well looked after do not have to cost the earth at MOT times!!!
Am one very happy 318 owner again!! :D
Cotty
Hartge Crew
Post Fri Feb 09, 2007 1:44 pm
Well done, mine passes a couple of weeks ago with just an advisory for a ball joint :D
dom-1984-320i
Post Fri Feb 09, 2007 1:47 pm
good news mate! mine also passed 1st time about 3 weeks ago and its 22 years old. If you look after them, they look after you! :D
RugbySteve
Post Mon Feb 12, 2007 8:40 am
The only two advisory bits I had, I already knew about, a tiny bit of potential rust is happening on offside rear wheel arch, which I want to sort when the weather gets a bit nicer and my temp sensor is still running hot which I believe is either a loose nut on back of dial or the actual sensor itself! (have already changed the thermostat!!) But they are little jobs to do when its not raining at a weekend!!!
Main thing is she passed and with some tlc this year will hopefully pass next year!!! Just need to scrub in my four new tyres now!!! But they are already more grippy than the bald ones taken off!!! Less entertaining though!!
Post Mon Feb 12, 2007 9:11 am
RugbySteve wrote:The only two advisory bits I had, I already knew about, a tiny bit of potential rust is happening on offside rear wheel arch, which I want to sort when the weather gets a bit nicer and my temp sensor is still running hot which I believe is either a loose nut on back of dial or the actual sensor itself!
Neither of these are "advisories" in the MOT test sense.
Just the tester pointing out a couple of minor problems, I expect.
cliffybabe
Powered by Nelly
Powered by Nelly
Post Mon Feb 12, 2007 9:27 am
:banana: congrats
slinky
Post Mon Feb 12, 2007 12:43 pm
Nice one, it's great when they get through the MOT. Mine 318i got through 1st time a few weeks ago as well. 1st time that's happened in a while! :D
Pal318is
Post Mon Feb 12, 2007 12:52 pm
Result Buddy :cool:
Good feeling to know that your not gonna get stung, like some of us have :cry:
Pal
Pal
Image[img]http://Image
