318is - Non Starter
tommoh3000
Post Fri Feb 09, 2007 10:56 am
Hi everyone
My 318is will not start !!!! It was fine until last night when all the dash lights went really faint, got home fine. I switched it off on tried to restart and it was not even turning over. This morning I went out and it turned over a little but not enough to start up.
I was hoping that maybe it was just because of driving in the snow all day that maybe the battery got wet ?
I have no mechanical experience though, so please can you help !!
Tom
Chris-W
Post Fri Feb 09, 2007 11:03 am
Either the battery has failed and refused to take a charge, or the alternator has failed and won't charge the battery.
I'd try the battery first, myself.
tommoh3000
Post Fri Feb 09, 2007 11:06 am
Could I test the battery by running jump leads from another car ? If it cuts out as soon as I remove the leads will I know that its the battery ?
Tom
whipsey
Post Fri Feb 09, 2007 11:31 am
no i've had cars where i've jumped started them then removed the battery and still kept the car running
Morat
Post Fri Feb 09, 2007 11:33 am
That would probably mean it was the alternator...
tommoh3000
Post Fri Feb 09, 2007 1:45 pm
Thanks for your help, everyone
Tom
