Rear Beam
buffly
Thu Feb 08, 2007 5:37 pm
Hi there folks, just in the process of building a dedicated e30 circuit racer. Have fitted a set of Gaz coilovers and was wondering if anyone on here has actually raised the hieght of the rear beam, to get it closer to the body, and in doing so, reducing the negative camber of the rear wheels. At the moment, its sat on the floor, but there is way too much negative camber! Any response would be appreciated! Cheers, Rich.
hawkwind
Thu Feb 08, 2007 8:21 pm
What about a set of eibach adjustible rear arms? XL sell these http://www.xlraceparts.com/index.asp?fu ... ductid=188
HTH
p.s if you dont mind me asking how much did you pay for your Gaz coilies?
buffly
Fri Feb 09, 2007 12:47 pm
I piad £628, + VAT, from GAZ direct. I simply e-mailed them with my requirements and they were very helpful. Took 4 weeks for them to manufacture them, and deliver them. Delivery was about £12.
Where are those adjustable rear arms mouted on the e30? I cant quite picture it!
Godspeed
Fri Feb 09, 2007 8:14 pm
where do those adjustable arms fit then ?? dont they fit them to the E36 not the E30
oldbimmer
Mon Feb 12, 2007 8:00 pm
Have a look here:
http://www.k-mac.com.au
All the camber/castor adjustment you could wish for for both front and rear..
TRACKM3
Wed Feb 14, 2007 9:50 am
Muzzi Motorsport does a ally rear beam bush -12mm so moving the beam upto the body by the same amount, it will reduce a small amount of camber, but you may also need to re do your trailing arms (rose joint new mounts and new pivots) i have used and get the muzzi bushes for a fair few guys for track day use.
regards
Martin
