Eoins 325 sport
eoiny
Post Wed Feb 07, 2007 2:56 pm
eoiny
Post Wed Feb 07, 2007 3:46 pm
Here are some of the photos of the car and the problems that have to be solved!any useful feed back welcome!pics are of both rear arches,inside of the floor,you will see the wet parts and some pics of under the bonnet,thanks eoin.
p.s. trying to find where that wire connects in the dash,havent looked to hard though...
back left arch starting to bubble a bit
rear right arch rust probably under kit
engine bay seems clean and runs smooth without any problems
starting to bubble hear,also has some condensation inside boot lid
little rust hole here think a plate will be needed
seems like a rubbery sealent here also has got a little whole
misterious wire wrecking my head,speedo side of dash is not lit up and is not telling speed or putting miles on the clock.
the carpet is wet here see the different colours between the carpet.
has taken a bang here cause the car is so low,so must have damaged the metal and is leaking.
again the same problem here as the passenger side.
has a little hole in it and leaking too!
bimmaman
Post Wed Feb 07, 2007 3:54 pm
I like this pic the best!! :cry:
