wont run propperly
hass
Post Wed Feb 07, 2007 9:45 am
hi guys ive got and 325 m20 early setup(before 1988)
basicly the car was sitting for 3 months
then my customer wanted it back on the road.
i got the car to the garage and started her up
the car runs and idles but wen u go the rev it it misses
ive swapped over bits from my e30
h.t leads
distubitor
rotor arm
fuel pressure regulator
air flow
plugs
ecu
also done a compression check
everything seems fine
i might have missed some thing out
please help
hass
SPADGE
Post Wed Feb 07, 2007 9:52 am
Hass did you receive the ecu i sent you?
hass
Post Wed Feb 07, 2007 9:54 am
yea im just doing your feedback :P
recieved it yesterday
thanks spadge :thumb:
SPADGE
Post Wed Feb 07, 2007 9:58 am
hass wrote:yea im just doing your feedback :P
Ok mate cheers :wink:
Post Wed Feb 07, 2007 1:36 pm
Air leak? Split in AFM to TB air hose?
hass
Post Wed Feb 07, 2007 7:06 pm
hi brainmoooore
thanks for the replie
but ive also changed them :cry:
still the same.........
riklusby
Post Wed Feb 07, 2007 9:02 pm
Sticky gate in the air flow meter ?
hass
Post Wed Feb 07, 2007 10:08 pm
changed the air flow meter too :cry:
Post Wed Feb 07, 2007 10:56 pm
You've virtually changed the engine then, haven't you?
Exhaust blocked? Completely renew the fuel?
Post Wed Feb 07, 2007 10:57 pm
Injector loom connector under the inlet manifold isn't in the list!
hass
Post Thu Feb 08, 2007 5:15 pm
it hasnt got an inlector loom under the inlet manifold :?
i havent changed the fuel but it could be :?
i carnt see it doe
bobafett
Post Thu Feb 08, 2007 5:23 pm
Broken valve spring maybe.
What ?! Drive straight officer......It's an E30 !
It's the Ultimate Drifting Machine.
hass
Post Thu Feb 08, 2007 6:08 pm
very quite possible
ill have to book it in again
next week and double check things
thanks guys for helping
hass
