Replacing bonnet cable
tonydavis
I'm going to have to replace it quite soon on my M3, if it should break before i get round to it, how easy is it to open the bonnet without it?
march109
not too hard, required tools torch and a screw driver.
jibowski
it can be a bugger, my cable snapped
if i remember correctly I undid the two screws holding the passenger side grille on (you cant get at the top clips if bonnets stuck shut), carefully lifted the grille up and used a socket driver to undo the two bolts holding the catch on, the bonnet should open then when you lever the catch open through the hole in the bulkhead.
Its quite easy after that to lube the mechanism when removed and thread a new cable, it passes into the paasenger side cabin though a hole near the fuse box, you have to take the glove box out to make getting at the lever easy
mrLEE30
a hole in the middle of the catch, stick a flat screwdriver in there and turn can be accessed from through the slats in the grill with a long enough screwdriver.
