Soft Top Electrics Fault
215m3
Post Mon Feb 05, 2007 6:50 pm
I have just bought a soft top and the electric roof worked. The motor was replaced so it's not the original motor. 1990 model.
I went to put the hardtop on this evening and all it did was make a clicking at the back. It sounded like a relay clicking.
Is this noise common if the motor is faulty?
I lowered it manual and notice the motor that disconnects to lower the roof, when engaged back, the spline did not dissappear completely, if this makes sense.
Any thoughts
Toby
1987 E30 M3 S14 Turbo
1971 V12 E type Roadster
Cabrio
Post Mon Feb 05, 2007 6:57 pm
Is the top casing still intact and is the bar bent!!
Top casing expensive unless buy repair from E30 centre...dealer for the bar...relays normally good its the mechanical parts that fail if now in coreect position or adjusted properly when new motor fitted etc
215m3
Post Mon Feb 05, 2007 7:18 pm
What do you mean buy the top casing?
Toby
Cabrio
Post Tue Feb 06, 2007 3:40 pm
The motor that operates the roof mechanism has a casing made of alluminium made of two parts screwed together and by top part I mean the top half of that casing....its simple if you look at it
DaveD
E30Zone Wiki Specialist
Post Tue Feb 06, 2007 4:01 pm
This usually is the flap drive motor that clicks ..i presume the flap didn't rise ...the gears have stripped...get a new one (second-hand) try jason in walsall its where i got mine...the bmw centre 07871662902 .......top man
this might help ...at least you might know a few of the problems
http://www.e30ic.com/powertop.htm :(
Cabrio
Post Tue Feb 06, 2007 4:17 pm
As stated by Dave, Jason is a good bet for the roofs he has many parts for the E30 convertible and he is the one who has made the replacement part for the casing that breaks
If the flap is not lifting at all it could be the middle motor for the flap or the cables that need adjusting...if you are near Wolverhampton which is where Jason is location his company is the E30 Centre or speak to his brother Bill BUT probably best you take the car to them rather than mess about and make it worse
Good luck
Bally
Post Tue Feb 06, 2007 4:37 pm
Jason is really hot on electric roof issues, I was amazed at his expertise, my leccy roof did not work the arm was bent , he took the arm off put it in a vice ,put a new one next to it and straightend the bent arm to the exact angle as new one, refitted got it spot on first time, also while i was there the car would not start, told him i had this prob a couple of times and needed to check the fuse, He looked at the fuse and without looking in the car told me I probably had a coin sliped into centre console that was shorting the cig lighter right again, had me sorted and back on the road in an hour, well worth the trip from London , BMW would have fitted new parts and charge a couple of hundred. also nice to see some of the other stuff he is working on.
lukescott
Post Tue Feb 06, 2007 5:32 pm
I wonder if Jason ever fancies a trip to Dublin. I could organise a few cabs to have thier roofs serviced (preventive work) and this could pay for his weekend.
