318iS H reg. I went to order a new fuel tank from GSF and they said post 89 models only had one part number showing and that was 63L.
Single fuel sender unit.
I thought the 318iS had the smaller 55L tank.
What size tank?
geo1400
I replaced my tank 318i on a F plate with 55 litre. Bought it from Europarts, I think I done that because I wasn't sure about GSF.
Try Europarts would be my advice, I started out with a 63 litre and it just didn't fit. Big waste of time and money!
Geo1400
Geo1400
In what way? Body shells are the same.geo1400 wrote:, I started out with a 63 litre and it just didn't fit.
orangecurry
Brian - I assume he meant he started out with a 63 litre from GSF/Europarts, and it didn't fit
have a look at this Tom
http://www.e30zone.co.uk/modules.php?na ... ht=realoem
E30Mark
318iS is a 55L tank.
GSF part # B29300 £85 +VAT
PM for details
PM for details
geo1400
Brianmoooore wrote:In what way? Body shells are the same.geo1400 wrote:, I started out with a 63 litre and it just didn't fit.
Not only was it a double sender unit I'm sure I found it really dificullt to get it in. Even when it was in (just) there wasn't enough clearance for the Prop. Maybe cause it was aftermarket it needed a bit more persuation but I didn't want to wreck it.
Anyway sold it to a zoner and he had no probs.
Geo1400
tomstickland
Excellent info, thanks!
tomstickland
Are there any other parts I could replace at the same time? I'm thinking new rubber hoses and sender unit seal.
What size rubber pipe is it? I'm going to replace the whole lot.
geo1400
Be prepared for rusty fuel lines, they run from the pump along the top of the tank and down along the nearside sill. They were an unexpected problem for me, kind of crumbled away!
Geo1400
Geo1400
