cruise control parts list
dark_sounds
Post Sun Feb 04, 2007 12:12 pm
ive taken out the dash, just wanna know what it involved when removing the cruise control, want to remove the full kit, from the looks of it, the wiring loom was attached to the inside of the dashboard, and the ECU lookedl ike some small little box above the glove box, is that right?
what parts do i need? to make the full kit please :)
thanks
Templ8e30
Post Sun Feb 04, 2007 5:34 pm
You'll need:
ECU and bracket (above the glovebox)
Steering column stalk
Clutch switch and bracket (unless it's an auto)
Green slide in connector on the back of the instruments
Wiring loom
Actuator and bracket (next to airflow meter)
That's pretty much it.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
klu99apm
Post Sun Feb 04, 2007 5:38 pm
To make a full kit you need,
The control stalk
The ECU above the glove box
The wiring loom
The clutch switch and mount (assuming from a manual)(not essential)
The green connector block thing from the back of the dash
The motor/actuator and cable thing from the engine (mounted by the AFM)
Think thats everything!
