OBC Question Sorry
cliffybabe
Powered by Nelly
Powered by Nelly
Post Sat Feb 03, 2007 6:06 pm
Guys
Im currently sorting out the loom for fitting the obc tomorrow, I have found a connection in my lower left wing area which has a connection type for a temp sensor to plug in, Does this mean all i have to do is plug intot he bulk haed for the connection??
Neil
stuartgallafant
Post Sat Feb 03, 2007 6:09 pm
probably... most E30's came with the loom already in the cars, then as the options were selected, the parts went on
cliffybabe
Powered by Nelly
Powered by Nelly
Post Sat Feb 03, 2007 6:12 pm
cheers stu (and thanks for the stalk) :cool:
stuartgallafant
Post Sat Feb 03, 2007 6:42 pm
no worries :thumb:
gazza
Post Sat Feb 03, 2007 8:38 pm
cliffy if its right behind the n/s headlight then its the loom plug for the intensive wash wipe set up they look similar
ive never come across a car pre wired for a obc though
Post Sat Feb 03, 2007 10:01 pm
OBC loom is completely seperate and NEVER fitted to cars that don't have an OBC.
The connector you've found, especially if it's yellow, is most likely a fog light connector.
cliffybabe
Powered by Nelly
Powered by Nelly
Post Sun Feb 04, 2007 1:17 am
cheers guy, ill use that plug then for the obc and trace the loom back and use it :cool:
stuartgallafant
Post Sun Feb 04, 2007 12:30 pm
Brianmoooore wrote:OBC loom is completely seperate and NEVER fitted to cars that don't have an OBC...
thats a bummer!!
cliffybabe
Powered by Nelly
Powered by Nelly
Post Sun Feb 04, 2007 12:53 pm
its going alright have found another plug i had so im making a new loom for that piece :cool:
stuartgallafant
Post Sun Feb 04, 2007 12:54 pm
you are a clever little fella arent you!!!
