Thermostat Housing
Cyruz
Post Sat Feb 03, 2007 5:17 pm
Ahh fun times, car is running for 2 days then I break it again...
Just a quick question, I was tightening the hose clip on the connector on the bottom of the thermostat housing that leads to the throttle body and it snapped off and left 1/2 of the L shape connector still inside. If I order a new one from GSF will it have the L connector already in it or do I have to source one seperatly?
I tried to make this clear but it's hard without photo's...
Thanks Jim
Cyruz
Post Sat Feb 03, 2007 5:47 pm
Been checking out GSF and can't see anything refered to as an L connector, I'm assuming that this doesn't come with the thermostat housing. Is this something I need from the stealers?
Cyruz
Post Sat Feb 03, 2007 8:04 pm
Bump, this is a daily driver so I need to know ASAP :cry:
Andy335Touring
Post Sat Feb 03, 2007 8:26 pm
Which engine ?
Pics would be handy too :)
Cyruz
Post Sun Feb 04, 2007 1:02 am
Bugger me, I always forget that. It's a 2.5 m20 engine. I can get a pic on Sunday, will amend the thread then...
Post Sun Feb 04, 2007 10:13 am
Never realised it was a seperate bit, so I've just had a look at a couple of 325s. It is seperate, but looks factory fitted, so, I doubt if it comes separately. Not on the ETK either.
One point, though. On one of the 325s I looked at, the piece is L shaped. On the other it was straight.
Cyruz
Post Mon Feb 05, 2007 12:01 am
I was hoping Brian would show up to shine some light on my dull situation... I've got one arriving from GSF on Tuesday so I hope it's connected. Is there anyway to replace the thermostat housing without removing the inlet manifold as although it's an easy job I always loose all the washer on my gravel drive...
I also have to ask, is there anything brianmoore doesn't know about e30's... the man is a walking bmw manual.
kam-325i
Post Mon Feb 05, 2007 1:23 am
Yes there is, but it is very arkward.....you need to remove the long studs that bolt the housing to the head.
It can be done.......with a lot of paitence.......
