fitting clifford concept 600 alarm
DJ_B4L
Fri Feb 02, 2007 3:17 pm
i have a clifford concept 600 alarm which was fitted to one of my previous cars i want to fit it to my current car
i have a clifford concept 300 on one of my other cars
i want to connect mine the same way so when the alarm is on you turn the key and it doesnt get power untill you turn the alarm off
how do i do this?
i also have 2 meta security window modules that were in the car when i brought it they are all wired up but i was wondering if i can connect these to my clifford alarm?
PIONEER AVIC X1, X1R, X1 BT LATEST SATNAV DISK WITH LATEST MAPS AND ALSO UPDATES FIRMWARE £20 POSTED PM FOR MORE DETAILS
Number plate for sale E30 2 HRD open to serious offers only will suit any E30
cliffybabe
Powered by Nelly
Powered by Nelly
Fri Feb 02, 2007 5:20 pm
i know ur need the clifford module to make the windows roll up :cool:
DJ_B4L
Fri Feb 02, 2007 5:55 pm
doesnt the clifford alarm have a output that can work with any window module i thought it was just a signal to close windows once the alarm has turned on
kam325itouring
Fri Feb 02, 2007 8:43 pm
yeah it is just a signal you can either use a neg when armed output from the 600, or you can use one of the aux outputs too so when you activate aux you can put the windows up without activating the alarm. if you want the distructions i can e mail them to you, just confirm what alarm you have.
kam
DJ_B4L
Wed Feb 07, 2007 11:21 am
how can i have the above setting on my clifford concept 600 so that when the alarm is on and if you insert the key into the ignition it wont have any power there at all no even to turn the headunit on when you turn the alarm off it comes on
DJ_B4L
Wed Feb 07, 2007 10:44 pm
can the alarm work without the wireless fuelgard i think i left this in the other car
stuartgallafant
Thu Feb 08, 2007 7:29 pm
i am confuzzled!!! :mad:
Sharabi
Thu Feb 08, 2007 7:33 pm
mate i personally would not mess with any alarm system myself, prefer to get an expert fit it, Clifford like all other alrams are olny as good as the fitter fitting it.
I've known too many cars that have fucked up after "non-qualified" people start fitting them.
