nasty noise! help please
oakey
Post Fri Feb 02, 2007 12:30 pm
ive got a nasty metal sounding chunk...chunk...chunk noise coming from one of the rear wheel areas whenever i brake. the harder i break the louder it gets, the more gently i brake the quiter it gets-almost a squeak...squeak.. ...squeak. the faster i am going the quicker the noise repeats itself basicall it sounds like its making the noise each turn of the wheel. does this sound like the "caliper anti-rattle clips" to you?
Post Fri Feb 02, 2007 12:33 pm
handbrake shoes loose within the drum?
have you had the wheels off lately? have you got locking wheel nuts?
gooner1
Out humping Reindeer
Post Fri Feb 02, 2007 12:40 pm
Could also be the small screw on the brake disc, took me best part of 3 weeks to spot this on mine after changing to 15" bb,s from 14" bottletops. Drove me nuts trying to scource the noise.
oakey
Post Fri Feb 02, 2007 12:47 pm
it was after i changed the wheels that this started happening. yes i have locking wheel nuts- why?
how could the small screw be causing this noise?
is there anyway id be able to cancel out or diagnose what the problem without removing the wheel?
the clip on the caliper looks fine from what i can see but this is what i was told was causing the noise
gooner1
Post Fri Feb 02, 2007 1:52 pm
Think you,d be better off removing the wheel and maybe jacking rear of car up. Get someone to put car in gear,with engine running and see if you can isolate the noise.As for the locking nuts they could be too long due to your wheel change, the small locating screw on my disc wasnt done up properly and caused exactly the same noise as you described. Good luck mate.
stuartgallafant
Post Fri Feb 02, 2007 2:33 pm
but surely if the locking nuts were too long, then they'd make the noise everytine the wheel rotated. oakey says its when he brakes...
E30beemerlads suggestion about h/brake shoes is a common problem.. also, how could the small screw on the disc make that noise?
Post Fri Feb 02, 2007 2:44 pm
I replaced the rear pads and handbrake shoes on my 325, fitted everythng up and drove off down the road.
Click, click, click, got faster as I speeded up.
it turned out that the locking nut was slightly longer thread than the other wheel nuts and was catching on the edge of the handbrake shoe. It didn't do this before I put new shoes in as it had presumably already chewed a corner off or dislodged the old shoes. The solution was to grind off a mm of the end of the locking nut thread and it sorted it.
If you pull your handbrake up say 1 or 2 clicks does it stop making the noise when you drive?
oakey
Post Fri Feb 02, 2007 6:37 pm
if i pull my handbrake up it makes no difference. could it be the locking wheel nut if it only makes the noise when i brake?(it does seem to make a similar noise extremely quietly all the time its moving though).
also if it is the locking wheel nut would the noise not be coming from all the wheels?
the handbrake seems to work fine.
could it be the anti rattle clip on the caliper?
oakey
Post Fri Feb 02, 2007 7:32 pm
oakey
Post Fri Feb 02, 2007 11:40 pm
any more advice on this one?
Post Sat Feb 03, 2007 2:07 pm
I don't think it is the locking wheel nut dude, sorry not really much help
Post Sat Feb 03, 2007 2:22 pm
Swap the locking bolts with plain ones from the front.
