I really need help on this...I've been experiencing a strange problem with my car that I can't seem to solve.
Mine's an M40, whenever I get into start stop traffic or leave the engine idling for a long period of time, it loses power when I try to accelerate above 2000 or 2500 rpm.
Continue shifting up and driving conservatively for another 5 to 10 mins, it comes back to normal. But if I force it immediately and try to push the revs up, it does so after some hesitation.
But immediately after this, the engine dies at idle. I can restart it immediately but once you release the pedal it dies. After restarting, if I hold the pedal slightly, the engine runs very rough and puffs of black smoke comes out of the exhaust, ie. flooding.
Keep the revs above 2500, it's ok. Drive conservatively under this condition with the momentum of the car keeping the engine running and after 5 to 10 mins, it returns to normal.
This condition is also true if I drive the car after stopping when the engine has not completely cooled.
Tried all sorts of stuff but I can't get rid of the problem yet.
Initially, I suspected the fuel pressure regulator not releasing maybe excess fuel pressure, changed that. Changed the fuel pump as well.
After, that changed the engine temp sensor at the cylinder head as it does point to a temperature related problem. Checked the idle control switch at the throttle and the IVC as well, both functioning.
Injectors cleaned as well. Could this be a problem with the ECU or the AFM both expensive items, thought I'd check with u guys first.
Please help
Regards,
Vincent
