just tried searching for this but keep getting errors as i click search so well..
i need to know which pins i need to short to test if the fuel pump works
also which relay are the culprit pins under?
thanks
fuel pump testing
jon_pure_british
Clacton-On-Sea
Essex
Essex
smithy318i
Brianmoooore wrote: Pull out the orange fuel pump relay under the plastic cover on the inner wing near the air filter. Remember which socket it came from! Take a short piece of wire and short together pins 30 and 87 of the relay socket (pin numbers are marked on the relay).
Couldn't have put it better myself! Location of relay only applies to six cylinder cars. On four pots, it's under the wiring cover on the bulkhead.
jon_pure_british
i was looking for this exact qoute, but couldnt find it, as i raed it a few days agosmithy318i wrote:Brianmoooore wrote: Pull out the orange fuel pump relay under the plastic cover on the inner wing near the air filter. Remember which socket it came from! Take a short piece of wire and short together pins 30 and 87 of the relay socket (pin numbers are marked on the relay).
thanks guys.
Clacton-On-Sea
Essex
Essex
