hi all. in a 318i e30, i have a problem with a coolant leak...it is strange in that if i drive it downhill it p1sses the coolant all out, presumably onto the block, as when i stop and look i cant see any of it, however when i drive it uphill it doesnt loose a single drop...then parked on downhill slope to check it out it didnt leak again...it is very strange. Has anyone had any similar experience.
If not i guess its time to start stripping the pipes off and checking them for leaks.
strange coolant problem
gareth
are you losing any coolant though the 'nose' of the water pump? this is an obvious sign of the bearings giving out and the seals failing as a result (or more the seals failing and killing the bearings by filling them with coolant) every BMW engine i've had so far has needed a new one at some point so i guess these are a weak point?
not expensive to replace though, about £30 or less from GSF iirc and an afternoon will cover swapping it. if you do, pull the rad out and grilles off as it makes life a lot easier. then curse BMW for putting the bonnet hinges at the front!
gives you a chance to change the coolant too which is never a bad thing
failing that, top the coolant right up to the brim (to increase the pressure when hot to 'provoke it) jack up the front (use stands and chock the rear wheels too!!!) and run the engine up to temperature and look for weaping hose joints, splits in the rad etc. the pressure when it's hot should force some out of the offending new orifice!
