Ordered my new suspension kit, and I'm thinking i should re-new/upgrade a few other items to compliment the new setup, while its all in bits.
Can any of you guys recommend a list of parts to do along with the new shocks and springs?
Will be using car for trackdays etc.
Bushes? Which one's? etc etc...
Thanks.
New springs and shocks, what else should I get....
Milko
90' 2dr 335i - 220bhp and 206lbft - 1/4 in 14.7 @ 97 mph *FOR SALE*
kam-325i
ARB bushes front and rear.....
Theo
I would look at the following options;
A 2.5 engine - there is a world of difference between the 2.0 and the 2.5.
Bigger anti roll bars - your 320i will have 18.5mm front and 12 or 13.5 rear, these are pretty flimsy, bigger bars will help cornering alot.
If you haven't already, convert to rear disc brakes - using 325i trailing arms
Fully strip the car of all unecessary weight, carpet is a big one to get rid of (probably done this already)
Poly bushes may be worth a shout, powerflex do a front and rear kit for the e30, which will reduce movement in key areas, but there is some mixed feedback with these
I could go on, but I wont!
Hope this helps.
Hope this helps.
miniblob
As said really!!!!
Make sure your brakes are tip-top!!!!! Discs, pads & fluid (check it, or just bleed some new stuff through if you haven't already!)
Bushes, ARB's, Strut brace maybe.
Weight reduction - just depends how extreme you wanna go!!
They'll be the easiest/cheapest to do i would think!!
327 Touring with bass!!!
Milko
Thanks guys.
Its just the suspension I'm on with at the moment....
So poly bushes all round (what about these offset bushes to cure excessive camber?)
What about top mounts....?
Any links to a place that sells all this stuff, rather than me getting bits from all over?
P.S my 320i has rear discs already?
Milko
The poerflex bush kits offer 2 different types of bush for the wishbone M3 type and normal type, whats the advantage of M3 version?
