Rear Screen Heater for Convertible
jazzleeds
on my 325i convertible (1991) there is a switch for rear screan heater. it lights up when pressed but does not clear the window. are these cars fitted with rear screen heater and if they are how does it work.
thanks
thanks
cliffybabe
- Powered by Nelly
yeah there is a heater behind the rear seats, It should sound like a hair drywer going, Theres a litte vent in the middle behind th ebench have a look and see if ur's is working or even there
DaveD
- E30Zone Wiki Specialist
If you look on the back panel below the window you will see some slits ,this is the vent for the rear screen heater blower..it blows hot air onto the screen and if working you should be able to hear it.
http://www.realoem.com/bmw/showparts.do ... g=61&fg=25
to get to it you have to take the rear seat back out
mrLEE30
and only works with the roof up!!
jazzleeds
thanks very much for your help and information.
DaveD
now I never knew that!mrLEE30 wrote:and only works with the roof up!!
mrLEE30
there is a small switch under the roof cover on the passenger side (for your cars) can be seen near where the folding roof attches to the body, this closes when roof is fully down and stops the blower from working!.... i know this cause my sub woofer runs from this power supply and took me a few hours to figure out why i only had bass with the roof shutDaveD wrote:now I never knew that!mrLEE30 wrote:and only works with the roof up!!
mrlee
orangecurry
sounds like a good idea to me; Allah/God must have been guiding your hand - with your top down why should I have to listen to your awful taste in music as I drive past?
cliffybabe
- Powered by Nelly
orangecurry wrote:sounds like a good idea to me; Allah/God must have been guiding your hand - with your top down why should I have to listen to your awful taste in music as I drive past?
i never knew the heater did wiork with roof down
orangecurry
eh?
did you mean to type 'didn't'?
And of course the same connectors (and dash switch) make the rear screen elements work in the hardtop - how cool is that?
cliffybabe
- Powered by Nelly
well spotted due my badorangecurry wrote:eh?
stuartgallafant
cliffybabe
- Powered by Nelly
it could keep necks warmstuartgallafant wrote:am i the only person that can see that it makes sense that the heater ONLY works when the hood is UP???!!!
why the hell do you want to clear your screen when you're not even gonna be f*cking looking through it?!?!
orangecurry
wake up Stuart - now you are 3000, it seems dementia is setting-in
stuartgallafant
orangecurry
who's a knobhead?
stuartgallafant
orangecurry
good point - how many times have YOU locked yourself in a car boot.....
two times less than Mr Babe.
Ziggy
Aaaanyway, does the blower actually heat up the air that it blows at the screen? I've never bothered to check, & figured it was probably just a blower (which might explain why it's blimmin rubbish).
orangecurry
probably heats it up - it smells like it when you start it for the first time for months. It works well when the screen is frozen (I noticed this before I got a hardtop)Ziggy wrote:Aaaanyway, does the blower actually heat up the air that it blows at the screen? I've never bothered to check, & figured it was probably just a blower (which might explain why it's blimmin rubbish).
And you've never descended into pointless banter Ziggy?
cliffybabe
- Powered by Nelly
stuartgallafant wrote:neil, quite obviously.....
i know you say some stupid things, but neil is like a naive child...
Ziggy
Me?! The very picture of innocence. I just couldn't think of anything to say about the latest exploits of the Cliffmeister. To point out that he's quite clearly retarded, seemed a bit redundant.
I've never smelt the 'dusty electric heater' smell from it, so that might explain why my blower's useless! Methinks I should start looking for a new one, but I'll investigate first... Ta
Oh, & going further off topic - how do you get on with your hardtop? Been contemplating getting one for ages, but storage would be the biggest issue I think...
GDBN
There's a couple of wires that warm up ... warming up the air that passes over it.
Not a bad design for the early 80's me thinks.
G
G
I deserve 6 of the best ...
orangecurry
hardtop - swings and roundabouts.
plus:
Quiet, warmer, rear screen clears, no chance of water getting-in over winter, looks fantastic with all windows down (pillarless coupe stylee), less likely to be vandalised (cloth being slashed I mean) unless someone is trying to steal the hardtop itself
minus:
can't go topless on a sunny winters day.
I got a frame with mine that hangs on the garage wall, so the hardtop hangs on this from spring to autumn.
plus:
minus:
stuartgallafant
stuartgallafant
cliffybabe
- Powered by Nelly
Im specialZiggy wrote:Me?! The very picture of innocence. I just couldn't think of anything to say about the latest exploits of the Cliffmeister. To point out that he's quite clearly retarded, seemed a bit redundant.
cliffybabe
- Powered by Nelly
I do notstuartgallafant wrote:i hate those pricks... cliffybabe does this...orangecurry wrote:hardtop - swings and roundabouts....
minus:
can't go topless on a sunny winters day...
Ziggy
Would do, but I can't imagine there's a seperate feed to the blower & the heater element is there? Mine blows fine, I just don't think it heats...stuartgallafant wrote:ziggy, before you go changin the motor, check its not the switch that is f*cked, as quite often, this the case
Jealousy isn't a good look...stuartgallafant wrote:i hate those pricks... cliffybabe does this...orangecurry wrote:
minus:
orangecurry
Sorry which 'pricks' do you hate? And what does cliffybabe 'do'?stuartgallafant wrote:i hate those pricks... cliffybabe does this...orangecurry wrote:hardtop - swings and roundabouts....
minus:
Go topless? Go on the swings?
mrLEE30
bllody hell, i only said there was a switch to turn it off with the roof down!!! makes pefect sense to me, why clear a screen that is not there?
there are two supplies, one for the fan and one for the heater element, i would imagine the heater elements would not last too long if they are bounced about hot so if yours does not smell of burnt stuff when you first turn it on chances are the element is knackered. this bigger supply has a nice big wire and fuse, so it now powers my sub, roof up or down as i shorted out the offending little switch... and i am a God man thank you, although not met the fella yet!!
and i can only go topless in winter... its too hot in summer... do you hate me for that?? am i a prick??
and as for OC's comment on another thread... yes i do know a bit about pre facelifts i have not always been a techie 2 man
mrlee
mrlee
mrLEE30
and how the hell do you get loocked in your own boot??? TWICE ??? was there a wonam named Yolanda involved ??!! belive there was a song about that ice tea/ice cube/ someone of that genre...but if you do find yourself in that position again either by stupidity or by gangsters.. kick the rear lights out!!
stuartgallafant
Ziggy, beg ya pardon mate, I thought it didnt blow at all!!
orange, in case you're too dumb to interpret what i said, I hate w*nkers who have convertibles and deem it necessary to drive around with the roof down in January, wearing a coat and scarf... as you so clearly do. Neil is also a fiend for this stupid behaviour... however, I find it extremely dificult to hate him. He actually IS special
orangecurry
yeeeessssss it wasn't obvious what you were talking about though was it?
I'm with Ziggy on this - jealousy.
BTW I've even got one of those silk scarves with wires in it, so it sticks out backwards even when I'm not moving
Ziggy
No probs - thanks for trying to help anyway!stuartgallafant wrote:Ziggy, beg ya pardon mate, I thought it didnt blow at all!!
There really is no other reason for it. Doesn't affect anyone else in any other way...orangecurry wrote:I'm with Ziggy on this - jealousy.
Must... get... wired... scarf...!BTW I've even got one of those silk scarves with wires in it, so it sticks out backwards even when I'm not moving
All I have is heated seats & wind deflectors...
