e36 328i or 325i engine into e30?
telski789
Post Sun Jan 28, 2007 11:10 am
hi,i know this has probably been done! but i'd like to do it! just wondering whats needed to put a 328i motor in? is it much easier to put e36 325i engine in? although i'd prefer the 328i! if anyone has done it can you show me some pics?!!!cheers
Tel
mrLEE30
Post Sun Jan 28, 2007 1:01 pm
no real difference between 325 and 328 M52 engine. and even better a 328 with a 325 TB and chip.
whats needed depends on the age of the motor you are putting in (due to the later type engine immobliser system and later ones a double vanos (M45) ) but basically custom engine mounts and wiring loom needs splicing to get the guages to read/inginitio to work and the ECU needs changing to the correct (E36) type. then the gearbox and mountings are different, then there is the prop shaft which will require mods and depending on what car your using as a base the diff may not be man enough for the job, also worth noting unless you base car is a 325 then the rear brakes may be drums so not very good and the 4 pot suspension may also suffer from the weight.
big job... better to go the 2.7 route IMO cheaper and easier the M52 2.8 and 2.5 are the same power (192ish hp) but 328 with 325 TB and chip will be closer to 215hp .... but a decent M20 2.7 conversion will make 190hp fairly easy and 200+ with a cam and headers
mrlee
