318i to 325i conversion
chris318is
Post Sat Jan 27, 2007 6:35 pm
i have a standard e30 318i. i want to fit a 325i sport engine in to it, what will i need to complete the project? :cry:
clubfx2
Post Sat Jan 27, 2007 6:37 pm
I have a 320i, which is running surprising well, not wanting alot for it, can sell complete in a rolling shell if interested, can do a like for like swap.
jmc330i
Post Sat Jan 27, 2007 7:19 pm
chris318is wrote:i have a standard e30 318i. i want to fit a 325i sport engine in to it, what will i need to complete the project? :cry:
Engine (complete with loom, AFM etc), ECU, Rad (and hoses), gearbox, prop and diff. Basically, buy yourself a rusted out 325i and you will have all the bits you need. You also need to sort out mountings for the AFM and header tank - no big deal really.
Just a quick note, there is no difference between a 325i and 325i sport engine.
If yours is a 318i saloon, you will also need the front struts (shocks and springs) changing for the larger 51mm bits from the 325i - I say that although mine is running the smaller 45mm struts without problems so far.
James
'91 325i Sport
'93 318i touring 16v
