Haven't used my touring for a while (a few months) & i noticed the clutch pedal seemed high - i checked the fluid and that was rather low so i toped it up.
Can there b air in the system? - if so do i need to bleed it - or do i just need a new clutch?? - if so - is this a pig of a job??
My Clutch pedal is tooo High
You should have a pedal working near the floor if it needs bleeding.16azev_needed_for_my_e30 wrote:Haven't used my touring for a while (a few months) & i noticed the clutch pedal seemed high - i checked the fluid and that was rather low so i toped it up.
By this I mean the pedal should be as light as air until some way down the pedal travel at which point you'll feel the pedal go to normal weight for the rest of the travel.
May just be whatever else you've been driving if it's not slipping. Don't see the clutch would need changing cos it's been parked up for a few months.
lol, but gortour right there ,if by the floor could do with a bleed up by the sound of it. and some times driving another car makes yours feel a whole lot differentsnoops wrote:my sons 16 he sometimes uses my account, im 42 lol
The pedal height can be adjusted by slackening the nut at the pedal-to-clutch master cylinder pivot and turning the eccentric bush/bolt, then retightening - a quick, easy job.
Cheers gonna try adjusting it today - The clutch is definatley too high & although i do drive other cars the biting point is not right (perhaps all the drifting i did in it before i parked it up took it's toll on the clutch)
