Anyone know if you can get ECU fault codes out of a 93 vanos M50 engine?
The engine check light has come on a couple of times on my M50 engined touring after a few miles, (stays on untill you reset by disconnecting battery), and I would like to find out why.
M50 fault codes
Ant
- Retired Team Member
I'll chck the autodata book Brian OK,
favorite fault on those .... split balance pipe between the two banks of three on the intake runner, worth a spray
Email FTW
Andy325i
Hi Brian, are you running a vanos engine then?
what Loom ECU are you using?
Kind regards
Andy
Kind regards
Andy
Used the E34 loom. Extended the ECU end by about 300mm, so that I could fit the ECU in the E30 positon, with the three relays on the underside of the steering column support bracket.
Was a lot of work, and when I was do it again, I will mount them in a waterproof box on the battery tray.
Battery is going to be evicted to the boot anyway. (Have the bits from an E30 325SE), as I want the battery tray to mount bits for a LPG conversion, which will be fitted after a few months testing on the road.
Re my original post on this thread - The small breather hose from the cam cover to the air inlet hose was disconnected when I started fitting the E34 M30 air filter box, and I forgot to reconnect it.
No one has replied how to get the fault codes though. The USA method doesn't work.
Andy325i
not sure if my mate still has the fault code reader or if he hired it.
Will ask him tommorrow for you mate
elliot
sorry to go OT here but wherecan you get a fault code finder thing for an e30?
elliot
elliot
