2.7 with i pistons
Gabi_323i
Post Thu Jan 18, 2007 8:47 pm
ok so i have a 10.2:1 eta engine in my car. last night my timing belt slipped and one valve broke and made a huge hole in one piston, i bought 6 2.5 pistons, my question is will this work ok in the eta block? i also have the 2.5 head, intake, t/body etc
dimebag_from_hell
Post Thu Jan 18, 2007 8:48 pm
i wish i knew what all this stuff meant! :(
Jimbob
Post Thu Jan 18, 2007 9:15 pm
The block will need decking slightly (can't remember how much!) and the piston skirts will need shaving (bout 8mm I think from when I had mine done).
Gabi_323i
Post Thu Jan 18, 2007 9:24 pm
Jimbob wrote:The block will need decking slightly (can't remember how much!) and the piston skirts will need shaving (bout 8mm I think from when I had mine done).
i want to go turbo so i think i can benefit the lower cr :D i don't like the piston shaving too ... i thought it needed only with the 2.8 conversion?
Jimbob
Post Thu Jan 18, 2007 9:28 pm
you will have a higher CR but as most people only run 4-7psi the given CR will be fine.
If you don't shave the skirts they will hit the crank!
Post Thu Jan 18, 2007 9:33 pm
i'd use later 2.5 pistons then lower CR so more boost!
Gabi_323i
Post Thu Jan 18, 2007 9:42 pm
how can i have a higher cr if the pistons sits 2mm down the block??
Jimbob
Post Thu Jan 18, 2007 9:44 pm
The earlier pistons were a higher comp than later ones, i was assuming you had the earlier ones :?
and the reason for to lower the block was to have the pistons sit in the same place at their highest point
Gabi_323i
Post Thu Jan 18, 2007 9:50 pm
well i read a thread posted by mops
http://www.e30zone.co.uk/modules.php?na ... ht=stroker
and no one mentioned the piston needed shaving and the cr will be 8.3:1
Post Thu Jan 18, 2007 9:52 pm
we need a picture of the pistons!
Jimbob
Post Thu Jan 18, 2007 9:56 pm
Look for any other info (loads in this section) and Ant will have posted somewhere the piston skirts being shaved. Like I said, I've had it done myself and had a very good engine as a result of the work I've previously stated!!
Gabi_323i
Post Thu Jan 18, 2007 9:58 pm
and i really don't know what 2.5 pistons i have, early or late, how can i found out? i take a pic tomorow
here is the 2.7, dead :(
http://i82.photobucket.com/albums/j266/ ... mag007.jpg
Jimbob
Post Thu Jan 18, 2007 10:01 pm
Here's my early piston:
Hope that can help.
kam-325i
Post Thu Jan 18, 2007 10:05 pm
the later 325i pistons have an inverted dome/dish where the flat section is on the early ones.
Gabi_323i
Post Thu Jan 18, 2007 10:06 pm
tomorow i will post pics with the pistons, i want to go turbo so i need a lower cr, i don't want to shave the block
Post Thu Jan 18, 2007 10:08 pm
kam-325i wrote:the later 325i pistons have an inverted dome/dish where the flat section is on the early ones.
otherway round dude!
kam-325i
Post Thu Jan 18, 2007 11:02 pm
Eh ???
later = lower compression 2.5 ?
Ant
Retired Team Member
Retired Team Member
Post Fri Jan 19, 2007 9:39 am
You can just about see in the Pic Jim has posted that the ex valve cutout is deeper in the early high CR pistons.
That section is quite a bit "meatier" on the early units when compared to the late.
using 8.8:1 with the 2.7 build will give a CR around 9.5:1 with all the usual stroker mods.
Skirts must be machined on the early pistons, it will not turn over otherwise !
Gabi_323i
Post Fri Jan 19, 2007 9:44 am
with the 2.7 block crank and rods and 2.5 pistons the piston will be 2mm down the block? i want a lower cr for turbo
Ant
Retired Team Member
Retired Team Member
Post Fri Jan 19, 2007 9:48 am
will give approx 7.4:1 CR then dude.
leaves a large squish band though, I'd certainly recommend uprated head bolts and welded waterways.
there is no cheap way to do what you want to achieve, reliably....
Gabi_323i
Post Fri Jan 19, 2007 9:57 am
so i have the late pistons :) i very confused :-s mops said that the comp will be 8.3:1 with the eta block
edit that was with the early 9.7:1
now i get it
i will have welded water chanels and metric blues, and a holset h2d :D
Gabi_323i
Post Sun Jan 21, 2007 1:47 pm
http://i82.photobucket.com/albums/j266/ ... G_0029.jpg
http://i82.photobucket.com/albums/j266/ ... G_0030.jpg
these are the 2.5 piston, are they late or early model? from what pictures i've seen i think they are the late 8.8:1 ones
OK if you're using the euro i head with the euro i pistons:
VOL = Volume of 1 Cylinder
CCV = Combustion Chamber Volume
CR = Compression Ratio
First we know that the i engine has a bore of 84mm and a stroke of 75mm so:
VOL = (1/2 BORE)squared * STROKE * pi
VOL = (4.2cm*4.2cm) * 7.5cm * pi
VOL = 415.63cc
We know that the engine has a stock CR of 8.8:1 so we can figure out the CCV:
CCV = VOL / (CR - 1)
CCV = 415.63cc / (8.8 - 1)
CCV = 53.28cc
What you will be doing however is changing the stroke to 81mm so the VOL changes:
VOL = (4.2cm * 4.2cm) * 8.1cm * pi
VOL = 448.88cc
Now using this and the CCV we can figure out the new CR, but the pistons will be 2mm from the top of the deck. So we account for this empty space by calculating its volume and adding it to the CCV:
VOL = (1/2 BORE)squared * HEIGHT * pi
VOL = (4.2cm * 4.2cm) * .2cm * pi
VOL = 11.08cc
New CCV = 53.28cc + 11.08cc = 64.36cc
Ok so we did all that just so we could do this:
CR = (VOL + CCV) / CCV
CR = (448.88cc + 64.36cc) / 64.36cc
CR = 7.97
are the above calculations corect?
Ant
Retired Team Member
Retired Team Member
Post Sun Jan 21, 2007 2:05 pm
Hmm, I vote late, what do the skirts look like ??
Gabi_323i
Post Sun Jan 21, 2007 2:33 pm
damn, i'll have to take a pic
how about the cr? :D
kam-325i
Post Sun Jan 21, 2007 3:04 pm
those are the same pistons that are fitted in my engine, which is the lower compression 8.8:1
scort300
Post Tue Jan 23, 2007 9:02 am
Hi everybody i'm new to this website, but very impressed. Now excuse my ignorance but the ETA block. Is that the 525e bottom end? what else used this? And what is the Euro head?
