lowest ratio diff?
mrfuzzyfelts
Post Wed Jan 17, 2007 1:29 am
what is the lowest possible ratio diff for an E30???
need one for pulling away not top end"
eko
Old timer
Post Wed Jan 17, 2007 1:32 am
4.4* on tourers!
316i/318i i think!
mrfuzzyfelts
Post Wed Jan 17, 2007 1:33 am
whats next after 4.4|??
kevo
Post Wed Jan 17, 2007 7:38 am
i've got a 4.45 from an e34 520i 1988-1991 model auto, what engine you got? if you've got a 318is you can put an e36 is box in and with this combo have a top speed at 6500rpm in 5th of 97 mph
kevo
Post Wed Jan 17, 2007 7:39 am
you can also buy a 5.54 ratio motorsport cwp from bmw directly but it costs about £700 ive been told.
mrfuzzyfelts
Post Wed Jan 17, 2007 11:48 am
is the 4.1.1 not as low as the 4.45
i aint got a clue how these work! :eek:
kevo
Post Wed Jan 17, 2007 12:22 pm
hiya i just p'md you btw.
with diff ratios basically the higher the number the closer all your gear speeds are. eg
a 3.64:1 will give on a 318is a 145mph (approx) top speed theoretically of course wheras
a 4.45:1 will give it a 120mph top speed and subsequently all the gears in between are shorter too.
kev
