LSD Diff differences
drifty325i
Post Tue Jan 16, 2007 1:52 am
Hi Guys looks like ive decided to got with the 2.93lsd diff for my v8 conversion.
But i need to no if its as strong as the 3.73lsd already have on the car?
As i have not seen the 2.93lsd yet i hope its the same size ?
the guy im getting it off said its a medium case, is that what mine is ?
the car will be running around 260hp at the wheels if that helps.
cheers
Post Tue Jan 16, 2007 8:51 am
Medium case diff will have no problems whatsoever with 260hp.
drifty325i
Post Tue Jan 16, 2007 10:20 am
Sweet mate cheers. will it still get off its arse with a 2.93 diff and 240 to 260hp atw ? .
in 5th is 2200rpm@100kph ?
Post Tue Jan 16, 2007 8:30 pm
Would think 2.93 is still a bit low if it has a gearbox with overdrive fifth.
Ideal if it has a direct fifth gear.
drifty325i
Post Tue Jan 16, 2007 9:54 pm
I think ill stick with the 3.73, 3050rpm @ 65mph, that will get up and go!
