Hi,
I have just picked up an '89 320i, (£450, 12 months MOT) it's pretty sweet, has a few minor issues, the biggest of which is the clutch.
It's fine most of the time, but If i leave my foot on it for a prolonged period of time, whilst in gear (i.e at roundabouts or lights). When i lift my foot off the biting point has shifted to right at the bottom (I barley have to lift my foot off to get to it) it's not a huge problem, as I just have to be more careful when pulling away, or leave it in neutral whilst sat still.
My housemate thinks it might be the hydraulic fluid leaking, but i checked the resvoir and it is full. I suppose it could still be a leak, but not very big.
Anyone have any other suggestions?
And if it is a leak, what is involved in fixing it?
Cheers.
Clutch Issue
eko
- Old timer
Most probably either the clutch slave cylinder bolted to the side of the gearbox and/or the clutch master cylinder bolted to the clutch pedal!
They are not overly expensive to buy replacements so for peace of mind maybe best replacing both.
It's likely to be the master cylinder if it's not using fluid, but master and slave should be changed together.
GSF and Eurocarparts have OE quality parts and cheap pattern parts available. The choice is yours!
Changing them is a couple of hours or so.
