Project car is back!!
eamo
Post Sun Jan 14, 2007 9:22 pm
Right lads —a finally I got her back after the respray. I know shes sitting a little high at the mo but this is due to the fact that its engine and gearbox less!!!
heres a link to how she used to look - http://www.bmwcarclubireland.com/galler ... ?album=165
For those that don't know, this car started out as a standard 320 with rear drums and 46mm front struts. It also had standard seats, no electrics, manual rack and manual sunroof. It had the standard chrome and sat on 14â€a bottle tops.
So what have I done??????
Well, lets start with the spray job itself. It's a bare metal respray. The shell was completely stripped —a interior, trims, dash, carpet, door locks, glass, lights etc etc. Luckily enough the shell was spot on —a no rust issues and no signs of crash damage. There was a couple of dings on the panels but these were filled accordingly. Underneath was spot on as well and 100% rust free. It seems it had been rust proofed before. However I decided to go the whole hog and spent a full day under the car hosing it and then wire brushing it down. It was then drowned in fresh waxoil again all underneath!! As the interior and carpet was out, I waxoiled the interior as well including the arches but they were solid as a rock anyways. I think we then put on 6 coats of paint and 4 coats of laquer in total. The only body panels I replaced were the 2 front wings as one had a big crease on it and the other had been painted before but it looked as if the paint had reacted before. So 2 new wings from BMW were ordered. I also removed the arial from the rear of the car and fitted an m3 arial to the roof instead. Looks wise, I wanted to keep the car as standard as possible and I am more of a less is more type guy. No mtech 2 kit for me —a just a front Is lip spoiler! I also as you can see decromed her! 15â€a bbs were treated to a refurb and the centres resprayed in black. These are now wrapped in new Falken 512 tyres. Smiley headlights were also installed along with new headlight and kidney grills. Various other rubber seals were replaced as well i.e sunroof seal, rear light seals etc etc
I also fitted smoked brown glass from an early 325 which I think looks the bomb!
Now on to the inside. Out came the crappy dirty white headlining and in went black headlining from a sport. Sport map mirror was also installed. The carpet was replaced with one from a touring which has a suede type texture as opposed to the crude ruffle type carpet. An electric sunroof was also retrofitted along with leccy windows. I also installed a13 button OBC as well as mtech 1 steering wheel. Crappy standard seats were replace with a houndstooth recaros with rear head rests.
Now the mechanics!!! First off the rear. Ok —a as the 320 has rear drums, I sourced an axle from a 325 which had disks. The old axle was dropped and I put up the 325 axle. In the process I replaced the brake lines, the sub frame bushes and the rear trailing arm bushes. Also I changed the hand brake cables, the wheel bearings, new brake callipers, new brake disks and pads, new hand brake shoes and rear brake dust covers. The brake hoses were replaced with braided ones. Before I put the subframe back up I painted it with black rust proof paint! Rear shocks are now new bilsteins with eibach springs and new top shock mounts. I put in a new 14.5mm arb from a convertible and new drop links as well.
Now the front —a out came the 46mm struts and in went 51mm with new inverted bilstiens, eibach springs, new top shock mounts, new callipers, new ate disks, new mintex pads, new wheel bearings, new brake dust covers, braided hoses, 21mm arb, new drop links, 2 new wishbones with m3 offset bushes, new tie rods and a power steering rack!! Phew!!! Oh and a new brake and clutch cylinder!!
So she now sits in my yard awaiting a s14 transplant —a albeit I,m not quite sure if it will be a 320is or m3 engine —a opinions please???
I know for some people what I did was probably completely overkill with how far I went with things. It wasn't done on the cheap either —a all parts came from my local dealer. In fairness I did get a savage discount and I do look after there I.T.
So I would appreciate your comments and feedback —a negative or otherwise and if you have any further advise it would be great!!
Now next step is finding m3 running gear!!
now how do i post pics????[/list]
eamo
Post Sun Jan 14, 2007 9:27 pm
Frenchy
Mad as a badger my mate restores Ford RS cars and goes mental when he gets started but I know were your coming from good on Ya !!
Our Irish cousins seem to be getting right into E30's what's the craic?
Alpina B3 3.3 Santorini Blue,White Buffalo hide with Blue Piping,Black Shadowline. No 242.
318 iS Diamond Schwarz.
Porsche 944 Turbo S,Special Order Black,Very Limited Numbers and Very Quick......;-)
eko
Old timer
Post Sun Jan 14, 2007 9:35 pm
Pat on the back for your commitment :cool:
Really has paid off,looks stunning!
snoops
Major Helmet
Post Sun Jan 14, 2007 9:50 pm
lol that is quite high
Frenchy
Post Sun Jan 14, 2007 10:05 pm
Bumpers need coour coded black inserts only IMHO.
e36boy
Post Sun Jan 14, 2007 10:11 pm
Do you do off roading in that mate :wink: Only jokin, I read what you put so i know its down to no engine and gear box. Looks really cool mate, Keep us posted.
cliffybabe
Powered by Nelly
Powered by Nelly
Post Sun Jan 14, 2007 10:12 pm
the link isn't working for me :cry:
eamo
Post Sun Jan 14, 2007 10:23 pm
cliffybabe wrote:the link isn't working for me :cry:
which one??
eamo
Post Sun Jan 14, 2007 10:24 pm
Frenchy wrote:Bumpers need coour coded black inserts only IMHO.
i think your right
eamo
Post Sun Jan 14, 2007 10:55 pm
sorted!
eamo
Post Sun Jan 14, 2007 10:59 pm
Frenchy wrote:Mad as a badger my mate restores Ford RS cars and goes mental when he gets started but I know were your coming from good on Ya !!
e30 scene is big now in ireland - loads of sports been diffed around the place!!!
Post Sun Jan 14, 2007 11:02 pm
Wot no side indicator repeater lamps on the front wings?! Don't you need them for the MOT or is it different in Ireland? Nice otherwise :wink:
Morat
Post Sun Jan 14, 2007 11:08 pm
S14? if it was an M3 I'd agree with you but surely you could get something with a bit more poke for the money? Don't have to go crazy... 2.8 M50 or maybe a turbo M20.
Lovely job so far tho Fancy sorting my touring? :)
eamo
Post Mon Jan 15, 2007 2:36 pm
320iSE wrote:Wot no side indicator repeater lamps on the front wings?! Don't you need them for the MOT or is it different in Ireland? Nice otherwise :wink:
not a fail on our version of the mot. its called nct here - national car test
gooner1
Out humping Reindeer
Post Mon Jan 15, 2007 2:54 pm
Think it looks the bollox mate. fair play to you.
e30mclow
Post Mon Jan 15, 2007 3:11 pm
Good to see all that work being done, I have mine ready for a re-spray now, much like yours to begin with, rust free. I can't wait, all the work is worth it. I'm gone the euro look road though and was thinking of smoothing out the side repeaters, it is FACT that we can get away with it? I was even gonna pop up to the local nct to ask. Fair play man, it's good to see more of us Irish gettin into e30's and not wreckin em.
eamo
Post Tue Jan 16, 2007 9:45 am
e30mclow wrote: it is FACT that we can get away with it? I was even gonna pop up to the local nct to ask.
sure is boss
e30mclow
Post Tue Jan 16, 2007 10:00 am
Thanks eamo I'm gonna do that this weekend. Did you just weld in a plate and fill them over?
eamo
Post Tue Jan 16, 2007 11:58 am
e30mclow wrote:Thanks eamo I'm gonna do that this weekend. Did you just weld in a plate and fill them over?
no - the wings came like that - pre facelift cars did not have side repeaters on the wings
